2004 f150 5.4£ starter circuit issues?
Over the past few months I have had issues with the starter not engaging. I have replaced the starter, starter relay(in fuse panel), ignition switch, battery is 9 months old and it continues to only start cranking intermittently.
When I turn the key slowly I can hear the relay engage/click then I'll back it off and try again till the relay clicks and the starter engages almost simultaneously. So what else between the relay and starter could it be? Any help or suggestions would be much appreciated! Thanks!
Well I kind of jumped the gun in replacing the starter and once I did I took the old one in to have it bench tested and it tested good. With that said the issue has continued. The battery and alternator tested good on autozone's computer but was showing low amp draw from the starter on both new and old starter.
