funky smell with fan on
Sounds like you may have a small leak in your heater core if you are smelling coolant. Coolant will basically smell like pancake syrup, a sweet smell. This is unfortunate because to replace it is a very time consuming process, basically the whole dash has to come out. There a few different way out there to remove a heater core, but none of them are really simple. A shop will usually charge you around $1k in labor to replace the core. Hopefully you have some Curry chicken stuck in there and its not a heater core Good luck.
Still sounds like a small leak in the heater core, even with this additional info. There is a electronically controlled blend door that opens or blocks flow of air across the heater core depending on whether your climate **** is on cold or hot. If you have the AC on, the flow across the heater core is blocked. That is why you won't smell it when the AC is on. Second, if it is a small leak it will evaporate before it can pool enough in the box behind the dash and leak into the car. Usually a heater core develops a pinhole leak at first and will grow over time.
where would it dump fluid on the floor if it was doing it?
is there a way to jsut straight bypass the heater core? I remember on old fords, a 2 foot section of garden hose under hte hood was good to go.
What is a good brand of replacement to go with?
also, I have a cabin air filter? that should get changed first or?
I also want to do a drain and fill of the cooling system... I have new OEM fluid for it, jsut haven't gotten around to it yet....
where would it dump fluid on the floor if it was doing it? The core is located behind the glove box on the left.
is there a way to jsut straight bypass the heater core? Sure, shouldn't be too hard. The inlet and outlet are on the passenger side firewall towards the top center. They are some sort of quick disconnect connections. Just detach (might want to Youtube that exact procedure), cut off the quick disconnect ends and plumb back together with a piece of copper pipe shoved inside each end and tighten down with two hose clamps.
What is a good brand of replacement to go with? A core is a core, just go to Rockauto and pick one.
also, I have a cabin air filter? that should get changed first or? If it's dirty or looks suspect, yes.
I also want to do a drain and fill of the cooling system... I have new OEM fluid for it, jsut haven't gotten around to it yet. If you do mess with the cooling system, make sure the front end of the truck is the highest point when "burping" the system of air. These F150's are known for trapping air.
well, it is getting worse, now I smell it even when I don't have the heater on, like if I have the a/c on, or when I first start driving and am at speed for a little bit.....
went to rockauto, the oem is a little over $100, and the replacements are like $25 ---- I will be getting an OEM
if I can figure out what size and options I need to get for a radiator, I might get one of those as well, and just change everything. I already have new coolant and an upper radiator hose, so I would just need the lower as well...
I won't get an OEM radiator though, that is like $450!
The smell getting worse sounds right, a pinhole leak will only get worse over time. Well prepare for a $800-$1200 labor bill from a mechanic to replace it or a full weekend if you are handy enough for a heater core replacement. I know several people who junked their F150 because the core went. I would leave the rad. As the saying goes, if it ain't broke don't fix it.
My radiator is probably due for a replacement.... hmmmm.... I did break off the upper nipple on it, and made a fix for it.... but yeah. I do want to change out the coolant, and I already have an upper hose, might as well swap the lower out as well, and a new, possibly more heavy duty radiator, if I can figure out what to get....
Been parked a couple days, now notice a puddle underneath right about the passenger firewall area.
Will look at the hoses and such tomorrow. Carpet inside is dry at the passenger foot area.
at this point, do you guys think it is for sure the hc, or something else?
as for the cabin air filter, I was seeing there is a jit that need to be added to make it replaceable?
might as well do this right. Any good tutorials on the hc replacement? Don't want to take out too much, haha
