High mileage mantainance
I posted earlier about acquiring my 94 F150 4WD 302 . I知 bringing it in to get the new clutch on Monday. I知 not in a spot to do my own maintenance so I知 planning on getting the following done: Clutch, full tune up, front brakes, rear wheel cylinders(getting gummy), rear brakes. Anything else that I should have closely looked at or serviced? 302 engine, 5 speed 4wd, 182000 Miles.
The engine is running great, no leaks anywhere, no overheating issues.
I changed the transfer case fluid in Feb before my son took it to fla. I can do the rear diff fluid on my own.
I'd have somebody looking at the Universals. Nothing quite so nice as going down the road and dropping the driveshaft. You can get by a few miles by taking the rear driveshaft off and using the front only but it'll drive a little weird.
I'd have the shop look at the water pump too. It can be loose and not leak right now but turn loose on a road trip. Probably need to have them check the fan clutch as well. Unless you know the alternator has been replaced, I'd want to make sure the bearing aren't about to fall out. All of these are relatively simple checks. It all might be fine. It could be factory original and about to take a dump.
Just got a call from the shop. He said the truck was running on borrowed time. We knew the clutch was bad, but he said he was shocked to see how bad the U joints were. He said my driveshaft should be on the side of the road somewhere. 🤣 Clutch and U Joints fixed today and he値l be moving on to check brakes, water pump,alternator and leveled and aligned. I知 thinking I値l be looking at a 2k bill. It値l be worth it to keep in on the road.
