throttle body spacer
If you do this, you'll need to run the truck on a dyno, and get it tuned accordingly. I think you already have the tuner, they will just need to tell you what values you need to program it to.
Around here dyno runs are about $100 for 3 shots, 4 if they like you.
Lowest I've ever seen was $20 for 3 runs at a local car show... so if you look around, you can find one for super cheap.
A larger throttle body has no benefits whatsoever unless you also do major internal engine modifications. Same with the aftermarket intake. Save your money and just do a Gotts mod to the stock intake.
https://www.f150online.com/forums/ar...3-f-150-a.html
