Short cycling - all new parts
The ONLY proper way to charge the system is evacuate it with a vacuum pump, then charge it with the exact weight of refrigerant that's specified. You shouldn't even be working on it without the proper tools and equipment. You might be able to get close with just a set of gauges - both low and high side. If the system has been opened, using a vacuum pump is mandatory, all air must be removed.
Best suggestion at this time if you don't have all the required equipment? Take it to a pro and have it done.
When you put the new compressor in, did it come with oil already in it? If not, the specified amount of oil must be added.
