Lug Nuts Swollen
Lug Nuts Swollen
Took my 2012 FX4 to the dealer for oil change and tire rotation and they came back to tell me that the technician was having a hard time getting the lug nuts off, then reseated, telling me they were stripped and swollen. The dealer is the only one ever to remove my wheels. Says new set required: 6 per axle, $7.50 a pop makes it over $170. Said the lug nuts are made with aluminum and this happens. Is that true? If so, is there an alternative replacement lug nut that won't deteriorate?
I had this issue with my 2005 Dodge Magnum car. The stainless covers over the steel lug nuts swell when the steel nut corrodes. Also, if you use an old style lug wrench it doesn't go far enough over the nut and bends/distorts the stainless cover so a socket does not fit any more. Only use deep sockets on lug nuts. I replaced my lug nuts with Gorilla lug nuts available on line.
I got the Gorilla lugs from Amazon. No stupid tin chrome cover on them.. Solid metal and chrome plated is all.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
So far so good on them.
Good luck!
Mitch
Good luck!
Mitch
It's funny, because even though they are tough nuts, I saw one already kind of messed up from someone rushing... ugh...
Thank you ALL for your wonderful comments!!
Who would have thought that lug nuts that look this sturdy would be so vulnerable to wear? I mean, my Michelin tires might actually last more mile than the lug nuts? And the fellow with the Dodge, I think it was, shows the industry has seen this for more than 10 years. Crazy.
Again, thank you all for your information and recommendations!
