Front Grill Cam Lense Cracked
Old 04-25-2018, 11:26 AM
Wmsims's Avatar
The front grill cam on my 2017 F-150 has a cracked lense cover. What is the replacement part?
Old 04-25-2018, 02:26 PM
I don't see just a lens cover, I think you have to replace the camera. It's around $85 from Tasca.
Old 04-25-2018, 02:55 PM
Wmsims's Avatar
Thanks. That's what I thought it would take. I'll take a look at Tasca.
Old 04-25-2018, 08:57 PM
Wmsims's Avatar
Okay, obviously I'm new to the F-150 and these forums. Where do I find info on how to replace the camera? It appears I've got to remove the grill. Where do I find info on that?
Old 04-25-2018, 09:58 PM
Remove 4 bolts at top of grille, remove all push rivets, remove rubber radiator support cover, remove push rivets at top of headlight surrounds and gently pull loose. Remove 1 bolt on each side of grille housing, pull out 3 retainer pins on each side of grille housing that hold rubber shield, disconnect 2 electrical connectors at top of grille housing, pull out grille assembly to access all other bolts needed to remove grille and ford logo. Go very gentle on headlight surrounds and make sure all retainers are lined up before pushing back.
Quick Reply: Front Grill Cam Lense Cracked
