Knock knock....it's NOT a rod!
Old 04-18-2018, 04:43 PM
Fbird's Avatar
2002 F150 5.4 basically stock. 225K miles. I have recently noticed a lower engine KNOCK??
It does NOT knock ALL the time.. just MOST of the time.
Is prevalent around 1600-2300 rpm, I have NOT been able to powerbrake and DUPLICATE noise?
I currently have the front diff out so I decided to drop the pan and take a look. I even pulled EVERY rod cap ( 1 by 1 of course) and plasti-gauged them....just because nothing felt bad...
Everybody was around the .0015-.0025 range (it is plasti-gauge so....not an exact thing) Doesn't get better than that....so buttoned everything back together.
BUT what else could/should I look at, I'm at a loss here. I would have swore it was a rod but numbers do NOT lie. (btw i am a 30 yr Journeyman Tool & Die maker....ye si know what .001 vs .005 clearance feels like)
any secret squirrel stuff with this 5.4 ..
Old 04-18-2018, 04:46 PM
Fbird's Avatar
Checeked torque converter bolts, flywheel, exhaust manifold leaks.... all good so far. Even tried pulling 1 plug wire at a time and driving it ....still knock (you can make a knock go quite if you don't fire the cylinder) Removed serp belt...drove it... still knocked
Old 04-18-2018, 05:30 PM
Well, if it is serious, it will get worse. Anyway that has been my philosophy about funny noises. Noises are hard to diagnose. I've been fooled many times.
Old 04-18-2018, 08:19 PM
Some 5.4's had an issue with piston slap.
https://www.f150online.com/forums/v8...n-summary.html
Old 04-20-2018, 07:04 AM
Fbird's Avatar
I have heard a piston slap on this truck ....usually only about 5 seconds when its first cranked up...COLD.
anybody got noise stuff about timing chains?....I can't picture a chain making this KNOCK ...but as I have stated....i am baffled.
Old 04-20-2018, 07:23 AM
Fbird's Avatar
youtube is my friend. By following a dead link in hte piston slap thread....i went to youtube to look for f150 noises...
I may have found my culprit... catalytic converter?
he's a little long winded but...sounds EXACTLY like what I'm hearing. Must figur out how to diagnos.
Old 04-20-2018, 09:44 AM
Beat on the converters with a rubber mallet.
Old 04-29-2018, 11:21 AM
Fbird's Avatar
Finally caught a break.... It was rattling pretty good upon first fire...i crawled under and could actually FEEL the knock INSIDE the front converter on the drivers side...
Old 04-29-2018, 02:52 PM
Thanks for letting us know! Glad it wasn't engine mechanical.
Quick Reply: Knock knock....it's NOT a rod!
