Oil Gauge reads halfway with key on engine off
Old 03-21-2018, 04:55 PM
Johnnycc's Avatar
Hello.
I have a 2018 5.0l with 3,500 km the oil pressure gauge reads halfway with key on engine off, Than after it is started it doesn't move.
Has anyone else seen this.
Old 03-21-2018, 06:44 PM
Sounds like either a problem with the cluster or the sensor.
Old 03-21-2018, 10:26 PM
Sounds like a warranty issue. Speak with the dealer.
Old 03-22-2018, 07:06 AM
Johnnycc's Avatar
Thanks for your input.
I called the Dealer they said that its normal . Doesn't make sense to me . I'm going to call another Dealer.
Old 03-22-2018, 11:42 AM
Wookie's Avatar
The "gauge" is nothing more than a fancy idiot light. It shows three positions, dangerously low pressure, normal pressure, too high pressure. If the key is on the cluster is powered up and some signal value is going to be gauge making it display some pressure. Once the engine starts the gauge will then jump to the middle of the display as long as everything is fine.
A real pressure gauge would move around depending on engine speed and temp. Ford hasn't used something like that in a long time.
Old 03-27-2018, 12:01 PM
Paul888's Avatar
Without the engine running it's absurd that Ford calls that normal. I believe if the pressure is 7 psi or greater the gauge reads halfway all the time.
Old 03-28-2018, 01:07 PM
I know in some Internationals I've driven when you turn the truck off, the gauges just sit there. But then you turn the key to on (preheat), the gauges will sweep.
I don't see ever on modern vehicles. The needles usually go to the rest position.
Quick Reply: Oil Gauge reads halfway with key on engine off
