Is this a failing power steering pump?
Old 03-19-2018, 10:39 PM
brfiesin84's Avatar
Normally a Power Steering pump is easy for me to diagnose- it whines.
However, I'm getting NO sound from it at all. However, my steering is very "jumpy", like I get power steering for a second and then It drags. As the car warms up, I get less power steering, and the higher the RPM the less power steering I get.
Its very cumbersome to steer the wheel, but I feel like I get some support at slow speeds, but its still jumpy. Still hard, but certainly not as tough as a true no-power-steering situation.
Anyway, My best guess is a power steering pump failure. It doesn't seem to correlate with any rack and pinion failure I've ever heard of, but its going to be cheaper to replace a Power Steering pump than diagnose it at a shop.
Anyone see anything differently?
Old 03-20-2018, 07:32 AM
Have you checked the fluid?
Also, have you tried exchanging the fluid?
Old 03-20-2018, 10:13 AM
brfiesin84's Avatar
Fluid level looks a little high actually. Could replacing fluid actually help?
I have 240k miles. I can try to replace the fluid but never would have guessed that could help?
Old 03-20-2018, 12:38 PM
Powersteering fluid is like hydraulic fluid. It should be replaced about every 100k/10 years. More if you do a lot of turning.
You should make sure it is in the proper level too.
Quick Reply: Is this a failing power steering pump?
