rear vibration
Old 02-21-2018, 05:03 PM
Codey Cobb's Avatar
rear vibration
hey guys,
i have a 2003 with 9.75 rear end about 5 months ago i took it to a local shop and had the pinion seal replaced. the guy never filled the rear after or torqued the pinion nut a bout a month later the rear went so i replaced the bearings to get myself home.i have since replaced all the inners of the rear minus the pinion race and the u joints were also replaced trying to get rid of the vibration any ideas would be greatly appreciated
Thanks alot,
codey
Old 02-21-2018, 06:32 PM
Your driveshaft might not be balanced or your axle shafts are messed up.
Old 02-21-2018, 08:57 PM
When you replaced the bearings in the diff, did you inspect the axles carefully because the lube in the diff lubes the axle/bearing wear surface? I don't know, the whole thing should be carefully inspected and rebuilt. Not torquing the pinion would cause the ring gear and pinion gear to be misalgned and ruined. I would think the gears need replacement. It's not clear in your statement if than was done.
Quick Reply: rear vibration
