Grinding noise from tire area when driving at slow speeds or hitting the break
Old 02-20-2018, 11:54 PM
wwinter5's Avatar
Exclamation Grinding noise from tire area when driving at slow speeds or hitting the break
I have a 2015 F-150 3.5L ecoboost with 42,000 miles. Lately I have been experiencing a grinding noice that is coming from the driver tire area. It usually happens when I first drive the truck for the day and will not happen again after a few miles of driving. The grinding usually occurs when I step on the breaks to slow down but it will also occur when driving at slow speeds (15mph or less). The grinding will not come back after I reach higher speeds unless I let the truck cool off for several hours then it will do it again for a few miles before going away. It does NOT make the grinding sound every time I drive and I have noticed that when it does happen, it is usually cold outside. Any ideas as to what the problem is??
Old 02-21-2018, 12:19 AM
juniorbonner's Avatar
could be some crud is on your rotor, or you could have a warped rotor, your brake pads could be shot, you may have the early warning of a bad front bearing.... those would be the first things I would look at.
Old 02-21-2018, 08:11 AM
silvercreek's Avatar
With 42,000 miles on the truck I'm voting on the brake pads. The rotors could be warped also.
Old 02-21-2018, 08:52 AM
x2 on the rotors/pads.
Sand/salt is hard on brakes.
Old 02-22-2018, 10:29 PM
wwinter5's Avatar
Break pads are new. I have been reading and saw some people are saying they have the same issue even with brand new trucks. They are saying it could be the IWE actuator.
Old 02-23-2018, 02:54 PM
2stroked's Avatar
Does the noise go away if you put the truck in 4Hi?
Old 02-26-2018, 06:27 PM
tcp2's Avatar
leaking check valve is often the problem. replace the valve. YG360 is the part number. happens when the diaphragm gets hard in the cold.
http://www.rockauto.com/en/parts/mot...lve+(vcv),4980
Quick Reply: Grinding noise from tire area when driving at slow speeds or hitting the break
