how to fix
Old 01-21-2018, 06:04 PM
Joe2167's Avatar
how to fix
just changed my battery in 2010 f150 now dome and carge light stays on
Old 01-21-2018, 06:09 PM
I suggest reading the OM. If you need another copy go here: https://www.fleet.ford.com/partsands...owner-manuals/
Here is the excerpt from the 2010 3rd Printing OM:
PANEL DIMMER CONTROL
Use to adjust the brightness of the
instrument panel when exterior
lights are on.
• Rotate the thumbwheel from left
to right to brighten the
instrument panel.
• Rotate the thumbwheel from right
to left to dim the instrument
panel.
• Rotate fully to the right (past detent) to turn on interior lamps.
• Rotate to the left position (past detent) to turn off the interior lamps
and to disable the illuminated entry feature. When the control is in the
far left position, it acts as a dome lamp defeat/override.
Note:
If the battery is disconnected, discharged, or a new battery is
installed, the dimmer switch requires re-calibration. Rotate the dimmer
switch from the full dim position to the full dome/on position to reset.
This will ensure that your displays are visible under all lighting
conditions.
Old 01-21-2018, 08:38 PM
Joe2167's Avatar
how to fix
Thank you will give that a try.
Quick Reply: how to fix
