Catalytic converter question
On my 02 f150 4.6 I currently have true dual exhaust, headers, and a tuner running on it now.
My current cats are rotted out near the tops and clogged in th rears. I’m lookinb in to buying new catalytic converters but don’t really want to buy the factory direct fit since they’re more expensive, restrictive, quite, and they would have to be cut at the Y to fit the dual anyways Could I get away with doing one highflow on each pipe without CEL as long as I do the o2 sensors, one after the headers and one after the cat? My tuner allows me to turn off my rear o2 sensors if that would help at all.
Right now I have my rear o2s off and the only occasional code I get is the bank too lean which I always had come in every now and then even before the Exhuast and tuner, so I know the o2s off don’t cause a code themselves
I can probably put one on when I do the new cats.,cuz I was thinking about it since you can tell Exhuast is uneven output coming out of tips. Thanks!Can your leave a link to that mod for me
