2000 F150 Harley vs F150 Regular GCWR ?
Old 01-15-2018, 10:38 AM
Jorge Abad's Avatar
I have a Ford F-150 Harley Davidson (2000) 2wd, V8 5.4 motor, automatic transmission and a rear axle radio of 3.73.
In the manual it indicates a “Maximum Trailer Weight” of 4,000 Lbs.(pounds); and other F-150 models with same specifications have a Maximum Trailer Weight of 8,700.
My question is if this is related with the Shock Absorber, Leaf Spring, Aluminum Drive Shaft of Transmission?
Old 01-15-2018, 10:54 PM
MitchF150's Avatar
Dunno, but I think the Lightning of the same era does not have that much of a "tow rating" either...
Might be due to the supercharger in the sense that it has more power than the trans can handle towing a lot of weight?
Good luck!
Mitch
Old 01-16-2018, 12:52 AM
It should have a 4R100 with a supercharged engine, and that's a pretty beefy tranny, they used it in the Super Duty with all 3 engines - 5.4, V10, and turbodiesel.
Whatever the reason, you should not try to tow more than the rating no matter what mods you do.
Old 01-16-2018, 07:03 AM
Jorge Abad's Avatar
The 2000 Harley Davidson, no supercharged. It's a 5.4 V8 normal aspirate with 260 HP / 325 Torque
Thanks Mitch
Old 01-16-2018, 09:15 AM
It comes equipped with the 260 horsepower Triton™ V-8 engine powering 20 X 9-inch, five-spoke cast aluminum wheels on P275/45R 20 Goodyear Eagle tires, the first ever 20-inch wheels on a Ford production vehicle. The Harley-Davidson F-150 is lowered one inch, with revised springs and sway bar, adding to the vehicle's brawny appearance.
*No it is not supercharged.
*4000# is because of the suspension modifications.
Old 01-16-2018, 09:19 AM
Jorge Abad's Avatar
Thanks;
What about the Aluminum Drive Shaft ? All the others F150 have Aluminum Drive Shaft ?
Old 01-16-2018, 10:41 AM
It's a mix.
My '99 F150 XL SCAB for example, had a 1 piece aluminum driveshaft.
My '07 F150 XL RC for example, has a 2 piece steel driveshaft.
I guess it depends on who they source their parts from. Haven't been able to figure it out.
I was at a lot one time, and noticed that the exact same config of a truck one had an aluminum and one had a steel 2 piece -- prices of the truck were exactly the same too on the window sticker.
Old 01-16-2018, 12:10 PM
Jorge Abad's Avatar
Yes, P275/45R 20 Tires, Max Load are 2,337 LBS at 44 PSI: have to be part of the case.
Old 01-20-2018, 12:31 AM
suspension and wheels/tires (an often overlooked area for towing capabilitoes)
Quick Reply: 2000 F150 Harley vs F150 Regular GCWR ?
