Replaced heater core now I have low almost no air flow
Old 11-22-2017, 07:49 PM
alexlovell1611's Avatar
A couple of days ago I replaced my heater core which was definitely bad cause it was leaking antifreeze. I put everything back together and now there is very low air flow except from the defrost. and can hear the blower motor working and can hear it changing speeds from low to high. thought it could be the blend door but when I switch from cold to hot I don't hear any clicking as if it was stuck. any ideas?
Old 11-22-2017, 08:29 PM
Supply info on your vehicle, year, model, etc.
You may have broken or loosened an vacuum line or the blend door may be broken. Just guessing.
Old 11-23-2017, 07:28 AM
projectSHO89's Avatar
None of those will cause "diminished" air flow, they will all cause misdirected or incorrect temperature airflow.
The only way that airflow can be diminished is that either the blower squirrel cage isn't rotating freely or either the intake or outlet air path is blocked or restricted.
Old 11-23-2017, 10:28 AM
He did indicate the defrost air flow was normal or that the air flow was diminished in all modes but defrost.
Old 11-23-2017, 12:10 PM
Ah, misread that, you're right.
Probably loss of vacuum to the control head, it defaults to defrost under that condition.
Old 11-23-2017, 12:40 PM
Check your vacuum lines from the engine to the control unit, especially behind the battery.
