cant get my turck to start
Old 11-13-2017, 07:40 PM
trevor0714's Avatar
Angry cant get my turck to start
i have a 2000 4.6 liter f150 with 4x4
i was driving down the road at 60 mph and the truck stopped running replaced the battery and checked the alternator and nothing has changed so far nothing i have checked has been none working like the fuses battery ect i have not checked the starter but i do not think that a bad starter will shut the truck off when going down the road so im not at a stand still any ideas would be appreciated thanks guys
Old 11-14-2017, 03:55 PM
Bluegrass's Avatar
Would you think maybe lack of power to the ignition and fuel injection might stop the motor?
Starter and alternator has little to do with it unless it is a no crank..
First what does the Theft light do?
Next what does the dash lamps do?
Next is there a CEL lamp on?
If no direction is indicated from the above, you have to begin the process of trouble shooting.
This does not mean changing parts on a guess.
First does the fuel pump run at key on for at least a few seconds?
If yes the computer is getting power so you can eliminate that as a cause.
If no, check fuses and PCM relay.
Next is the fuel pressure at the proper level?
Check with a gauge on the rail test port.
You have to get a beginning trouble indicator before replacing any parts.
Good luck.
Old 11-14-2017, 09:56 PM
trevor0714's Avatar
would the theft device in my key shut the engine off if the battery in the key died?
Old 11-14-2017, 10:06 PM
Bluegrass's Avatar
No. The Theft system has no more to do with the engines after it begins to 'run'.
The 'KEY' has no battery in it.
The lock function does in the Fob but has no control over anything but the locks and Horn/lights.
You have to trouble shoot the cause.
Good luck.
Old 11-14-2017, 10:16 PM
trevor0714's Avatar
could the truck come out of running if the ignition switch has been used some much its wearing down and just slips
Old 11-15-2017, 07:01 AM
enriched's Avatar
other things to check...check/clean your MAF sensor and your air filter for damage and the connection to the Crankshaft sensor.
have you checked the things suggested?
Old 11-16-2017, 05:43 PM
trevor0714's Avatar
i have checked all electrical alternator starter it has spark fuel pump is working everything on the in side works all fuses are good and running no cuts holes lose grounds or anything the only thing i haven't checked is the camshaft sensor because im not sure how to but i dont believe it would cause a shut off while driving i could be wrong
Old 11-16-2017, 06:12 PM
trevor0714's Avatar
okay so could it be the fuse-links if they break the alternator no longer can charge the battery right? after little bit the truck would die and not be able to start again or does the alternator and battery have different lines the engine isn't locked up
Old 11-16-2017, 06:31 PM
enriched's Avatar
what is the voltage on the battery after it dies? If it is still 12.2v or higher, doubt that it is a battery of alternator issue
Old 11-16-2017, 06:37 PM
Crank or cam position sensor. Sure, either one can cause a shutdown, the computer will no longer know the position.
