F150 no crank
F150 no crank
Hey guys. So my 97 is running for the moment. A he'll of a lot better since replaced plugs and wires. All but the two I couldn't get out. I also fixed the elbow that was missing. Anyway, Its probably something I did,but you never know with these fords. Haha. Anyway. Truck only starts with key on and if i bridge the starter solenoid posts. Does not start with igniton and when I try all the lights shut off and door locks move up and down. I can hear one little click coming from the dash. I also ran these codes.
PO750 shift solenoid A
PO755 shift solenoid B
PO708 Transmission Range Sensor A Circuit High
PO743 Torque Converter Clutch Circuit Electrical
Also my OD light is blinking on shifter which Im pretty sure has something to do with the codes that are showing. Let me know what you guys think.
The transmission range sensor is also the neutral safety switch. Probably needs replacing, if that fixes the no-start issue clear the codes and see if they come back.
http://www.rockauto.com/en/catalog/f...ge+sensor,4584
I've already tried moving the shifter when turning the key with no luck. Also when I took the battery charger off the battery instantly died. So either I'm drawing power from somewhere or the battery needs replacing. Everything worked fine before I changed the plugs and wires. Why I was thinking it might of been something I did when putting everything back together.
So I might have found my problem. I noticed my g101 ground location on the firewall next to the start relay the whole stud and connections are loose. I looked it up and everyone is saying thats a pcm ground? Maybe something to do with my codes and o/d light flashing, along with my no crank by the ignition. Let me know what you guys think.
I tested my battery, it is fine. As for anything else, I really can't check anything until I figure out my power problem. If my pcm isn't getting grounded, wouldnt throw my system out of wack? Everytime I tried to start the truck a week and a half ago, it did one click, all lights went out in the cab and my power locks started going haywire. When starting the truck, I used a screwdriver on the starter relay while the truck was hooked up with a battery charger. While it was running, that's when my OD light was flashing, and my obd scanner picked up the codes, but again,wouldn' it throw the wrong codes if it was badly grounded like that?
on
The PCM doesn't have anything to do with whether the starter will crank or not, it simply is not part of the starter circuit on a 97.
Your symptom is of a bad battery, battery connection or a bad battery cable which could be on either the positive or the ground side of the circuit.
Do start with cleaning the battery terminals as suggested, it's a common occurrence. After that, if necessary, use voltage drop testing (Google it) to identify the bad portion of the circuit.
The spark plugs can wait until you get the starting issue resolved.
