Hello from Washington
Greetings,
I just bought a new to me single previous owner 2007 Supercrew Harley Davidson in Purple. The truck has a little over 101K and is in great shape.
I need to fix the leaky 3rd brake light, and I just ordered a new fuel pump driver module as I have that fun driveline stutter under light acceleration when doing between 40 and 50mph.
So far I am loving the truck and hope to have it for a number of years to come.
David
David
If it has 101k and you are getting that stutter, it's more than likely it needs new spark plugs. Plenty of threads in both the V-8 forum and 04-08 forum about that. It's very possible that's one reason the previous owner got rid of it, didn't want to deal with the possible hassle of breaking them.
As for the previous owners, they are a mid to late 60's couple that decided that after 10 years they wanted a new rig. This thing is immaculately taken care of!
So, I have been chasing the 5.4 stuttering issue that occurs between 40 and 50 mph...
I started by checking and replacing the fuel pump regulator. Simple fix to make, and they are known to fail, especially in areas with high corrosion due to road salt. This did not fix my issue, but I have read that it has fixed the issue for others.
I eventually had enough, and had Ford do some tests. They found I had a sticking throttle body and a misfire on one of my coils. Instead of having them rape my wallet for the fix, I replaced all coils and the throttle body this morning (also replaced the fuel filter).
I just got cleaned up and will be taking it for a long test drive. I hope this wild goose chase will finally be over...
Fingers crossed!
Fingers crossed!
