Fuel Pump or not?
Old 08-16-2017, 08:48 PM
Brian Ensey's Avatar
Fuel Pump or not?
I'm having an issue with my truck randomly not starting I have changed out the fuel filter and also changed out the relays. Only does this at very random times. It never dies when driving only when trying to start, acts like its not getting fuel. Once it starts no issues. I've been told its the fuel pump, anyone come across this issue?
1997 Ford F150 V8 4.6L
Old 08-16-2017, 09:01 PM
Easy to check the fuel pressure on this vintage. Probably could borrow a gauge from Autozone or similar place.
Old 08-16-2017, 11:13 PM
I did that and it showed 30 psi.....
Old 08-17-2017, 05:10 PM
FLFordF150's Avatar
And what sods the manual say the pressure should be for your vehicle?also many times it seems easier to remove the bed versus dropping tank if you have to change pump.
Old 08-17-2017, 06:18 PM
28 to 40.
Old 08-18-2017, 10:40 AM
I've decided to just go ahead and change the pump. I've found several videos on youtube explaining the install and doing it by raising the bed. Thanks
Old 08-18-2017, 10:47 AM
If you turn the key on and get 30 psi, the pump works.
Old 08-18-2017, 12:24 PM
Are you getting any codes? I'd look for something else if it has 30psig fuel pressure.
Old 08-20-2017, 08:45 PM
Volfandt's Avatar
Iac
My 98 had a similar problem back in 2002. I don't recall if it set a code but it was still under the extended warranty and they replaced the IAC, the PCV and hose and cleaned out the throttle body. My records show it had 79850 miles on it.
When my fuel pump went out I had no problem starting it, it would just die intermittently. I'd wait 5 min or so and it would start right back up.
There were no codes set for this condition and I pulled the bed to swap it.
Good luck
Dave
