surging while on the breaks
I own a 2011 F150 eccoboost FX4. It currently has 43,000 miles. I took it in to my dealer for a battery and.the old misfire under WOT issue. They changed the coil packs, plugs, battery and said she was good to go. Upon picking up the truck, while holding the brake and selecting a gear, the truck starts to surge. It drives fine and isn't only noticeable when almost at a stop braking or release the brake to accelerate. The service tech claimed the cpu had to learn everything again.It didn't do this before and I am having a hard time getting the dealership I call me back. Anyone have experience with this issue?
Cross posted in breaks too.
When you say it's surging, is the engine speed actually changing or is it like the engine is trying to overpower the brakes? There is a vacuum generator on the EB that helps the brake booster work since there are times when the source of vacuum is not there. Ford extended the warranty on this part till 120,000 miles and 10 years on the 2011s. This might be your issue.
