ac Problems
Old 06-22-2017, 01:49 PM
Shaun Tucker's Avatar
ac Problems
Hello all, I'm having some ac problems that started out odd and just keep getting more strange. it started when I hit the gas driving the air would move from normal vents to defrost. Then it started from normal vents to the floor. Now it wont even activate the max ac setting... it blows cold out the proper vent until you put a load on the engine. I've replaced the check valve and looked for leaks but haven't found any vacuum leaks. any advice would be appreciated!
almost forgot to mention for a 96 f150 xlt with 5.0l
Shaun
Old 06-22-2017, 02:56 PM
projectSHO89's Avatar
Keep looking for your vacuum leak, you just haven't found it yet.
Old 06-22-2017, 06:12 PM
yep found .. the white hose that goes by the hood hing on the passenger side.. was a deceptive leak for sure.. thanks
