New wheels
What kind of backspacing are your Jesters? I just purchased some American Racing AR914's.
5.34 Backspacing with +15mm offset, wondering if I choose wrong.
Once they arrive going with the Cooper STT Pro's also 305/265/18.
After living with the Cooper STT's for a month what do you think? I've heard a lot of great things, great in Snow and Rain for a MT.
Also the Road Noise is minimal, considering they are MT's.
Also I'll gain almost 5,000lbs with my Towing.
Say what???
Going to a higher rated tire will actually HURT your tow rating as the empty vehicle weight increases. The tow rating is based on tires, axles, springs, engine etc. That all goes to create the maximum amount of weight the truck can pull and support under the manufacturer's guidelines. Anything you add to the truck should be subtracted from the payload rating. In your case probably 15-20 pounds per tire plus the difference in wheel weights.
Truthfully, a 1/2 ton truck doesn't NEED more than an XL or C rated tire. The semi-floating axles aren't made for more weight than that. The thicker sidewalls might help cut resistance on a trail rig but that's about it.
