Air Conditioner, Cruise Control, and Rear DRL not working?
Hello!
I am having an issue with my 2002 F150 with manual transmission.
All of these things are not working and they all happen to be on the circuit for fuse #5 under the dash. Logic points to the fuse as the problem, but it does not appear to be blown?
Any suggestions/insight?
Thanks in advance!
Thanks in advance!
I did change the fuse just to be safe, still nothing. I found that one of the wires underneath was cut last time we raised our spare tire, so that solved the running lights, but still no AC or CC.
The AC blows, but does not get cold, simple as recharging it?
The CC, I have no idea. All the fuses seem fine, just odd that they both stopped working at the same time, I was hoping they were connected in some way.
Thanks again!
Thanks again!
projectSHO89 You seem to be the man with answers. I'm having the same issue. Both my AC and CC went out at the same time. They would randomly start working again then randomly stop. Now the have stopped for good. Where should i start?
