Pcv valve?
on
on
Hey...I'm bringing this thread up again because I need help with a part # for the pcv valve and hose on the 5.4 3v...my truck is coming up on 100,000 miles, but I can't find a part # at Rock Auto, Autozone, Advance Auto or Tasca Ford. Can anyone help me out? Is it true that you have to buy an entire driver's side valve cover assembly?
Any help you guys could give me would be great!
Item Part Number Description
1 14A464 Positive crankcase ventilation (PCV) heater element electrical connector
2 6K817 PCV heater element tube quick-release fitting
3 W701724 PCV heater element bolts (2 required)
4 9F695 PCV heater element
5 — PCV heater element O-ring seal (part of 9F695)
Removal and Installation
Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
Disconnect the positive crankcase ventilation (PCV) heater element tube quick-release fitting.
Disconnect the PCV heater element electrical connector.
Remove the bolts and the PCV heater element. Remove and discard the O-ring seal.
To install, tighten to 6 Nm (53 lb-in).
To install, reverse the removal procedure.
Install a new O-ring seal on the PCV heater element. Lubricate the O-ring seal with clean engine oil.
The only one that matched was the snap connector hose but I had to get the pre and post numbers/letters to match it exactly. I hope the hose resolves the P0171&4 codes.
I found another thread that mentioned the elbow hose but that is for the 4.6l.
I don't have the manual but can some that does tell me if it shows how to disassemble the PCV parts so it would be cheaper then buting the valve cover?
I read those parts to the parts guy and he said they don't match the 5.4l? ...and you "have" to puchase the manifold cover to replace it. ...oh sorry, I have an '04 5.4l. Is it possible to do the same for my '04, or do I have to fork out $150 for the valve cover?
