How to identify your transmission
Old 05-14-2006, 05:54 PM
KR03F150's Avatar
How do I know what kind of transmission I have? I have a 2003 Supercrew 4x4, 5.4 automatic. Is there a tag on the transmission like the rear end or do you just have to look it up? Thanks.
Old 05-14-2006, 07:09 PM
dirtyd0g's Avatar
AFAIK all f-150's excluding lightnings since 98 or 99 have the 4r70w.
Alan
Old 05-14-2006, 08:07 PM
BLUE20004X4's Avatar
There should actually be a sticker saying 4r70w, but ya, aside from 5 speed manuals, 4r70w's are in all, 4r100 are in Lightnings. The new tranny is a
4r75w or something like that.
Old 05-14-2006, 09:49 PM
adrianspeeder's Avatar
Old 05-25-2006, 07:21 PM
Danoshere's Avatar
Actually the "new tranny" is 4R75E -- got one in my '05 SCab.
Dano
Old 05-26-2006, 02:51 PM
rkjerue's Avatar
Alan
Not necessarily I would check the sticker on the door, I have a 2000, 5.4, 4x4, Super-cab with a 4R100.
[Transmission Codes]
U — 4-speed automatic (AODEW/4R70W).
E — 4-speed automatic (4R100).
7 — 4-speed automatic (4R100).
Old 05-26-2006, 07:19 PM
Do you have the 7700 Package? Could you get a pic of your tranny and door sticker? It's not that I don't believe you, I just want to add it to the tranny info page as I've never seen a truck with your combo.
Adrianspeeder
Old 06-01-2006, 02:19 PM
rkjerue's Avatar
Adrianspeeder
No 7700 group. It did come with a factory tow package, I don't know if that matters. I could not get a good pic of the tranny but I know it is a not the same as the one on my 97 2wd 4.6 which was smaller and had a different shaped pan. I have sean pictures of a 4R100 and it looks the same as my tranny.
Door Sticker
https://www.f150online.com/galleries...0428&anum=2773
Here are the engine/transmission options from 2001 a brochure it should be the same as 2000. The description of the 5.4's tranny "w/electronic four-speed automatic" is different than all the other tranny's. I always assumed it was referring to the 4R100, in others words all 5.4's came with the 4R100.
- 4.2L EFI V6 engine with five-speed manual O/D transmission (NA on SuperCab 4x4)
- 4.2L EFI V6 engine with four-speed automatic O/D transmission (NA on SuperCab 4x4)
- 4.6L EFI V8 engine with five-speed manual O/D transmission (standard on SuperCab 4x4)
- 4.6L EFI V8 engine with four-speed automatic O/D transmission (standard on SuperCrew)
- 5.4L EFI V8 engine w/electronic four-speed automatic O/D transmission (optional on all models)
Old 05-20-2013, 08:33 PM
string's Avatar
03 trany
Door Sticker
I have an 03 screw 4x4 larriet off road with the 5.4 and the dealership could not tell me which tranny i need for my truck. apparrently their is two different types of trannies for this year. Their is no tag to ID the trany but it is the 4rf70
Old 06-06-2013, 09:15 AM
Did you read the whole thread before you posted? Look on your door sticker.
Old 06-10-2013, 09:05 AM
string's Avatar
The tranny is a 4r70 aode but found out that thier is a 1Lip and a 2lip but the dealership could not tell me what the difference is between is between the two.
Old 12-11-2015, 11:33 AM
Jaeger's Avatar
Okay, I may sound stupid, but there is no door sticker on my 2001 F-150 Lariat, how do I figure out which tranny I have?
Old 12-11-2015, 07:16 PM
Crawl under and look at the trans oil pan.
4R70W (but yours won't have the drain plug):
4R100 (note the "Utah" shape):
Old 02-10-2016, 08:22 PM
Shawn Harman's Avatar
2 types
According to this my 95 F150 Auto 2WD 302 can have 2 types of transmissions. Not sure if it helps but mine has the OD button on the shifter. Can you tell me if I'm mistaken or simply what tranny I have please? Thanks
Old 02-10-2016, 09:10 PM
Look at your pan. You have either a 4R70W or a E4OD. E4OD was replaced with the 4R100 around 1999 but it's essentially the same transmission. You most likely have the 4R70W.
Quick Reply: How to identify your transmission
