Airbag Reset Switch?
on
The salvage truck? I never saw how badly it was hit, but if it was hit hard enough to deploy an airbag, there should be a B1318 DTC stored in the restraint control module, indicating "crash memory full." You need to replace the RCM and all the crash sensors, maybe the seatbelt pre-tensioners if they were applied as well.
on
You'll need a CAN compatible scan tool to retrieve DTCs from the RCM. Anytime an airbag is deployed, all the crash sensors, the airbag(s) and the RCM must be replaced. The RCM has an arming sensor in it which is one half of what's required to deploy an airbag; these are one time use only, ain't no resetting. Plus, the RCM stores some crash data when the airbags were deployed. This is the "crash memory full" thing.
