Help! 8.8 posi is stiff after rebuild
Old Dec 5, 2017 | 01:03 PM
RJ Bright's Avatar
I installed new clutch packs in a 2004 f150. I got everything back in the diff the spider gears turned back into place but when I got rotate one axle it's like a welded rear end? The other side won't rotate in the opposite direction and instead of the spider gears spinning the whole different spins? Any help or answers would be appreciated!
Old Dec 5, 2017 | 01:08 PM
Did you soak the clutch packs in friction modifier overnight before installing? Did you use synthetic 75W140 with friction modifier in the diff?
Old Dec 5, 2017 | 01:13 PM
RJ Bright's Avatar
I soaked them for about an hour in 75w140
Old Dec 5, 2017 | 01:14 PM
RJ Bright's Avatar
Probably more like 3 hours of soaking
Old Dec 5, 2017 | 01:18 PM
RJ Bright's Avatar
Also installed now spider gears and side gears because the old ones were pretty much gone
Old Dec 5, 2017 | 01:26 PM
RJ Bright's Avatar
Not to sure how this blog works. Not sure if you saw what I typed yet. I'm pressed for time....
Old Dec 5, 2017 | 01:45 PM
Roadie's Avatar
I think it's supposed to work that way. When you drive it, does it chatter? Does it lock up when you step harder on the gas?
Old Dec 5, 2017 | 02:35 PM
You don't soak them in 75W140, you soak them in friction modifier, and you add friction modifier to the 75W140 when you fill up the diff.
