Widest tire for a 2014?
I am going to be putting an Autospring 1.5" kit on my 2014 and keep the factory 20" rims. What is the widest tire I can safely run on the 2014 and factory rims? Thanks for any help.
Thank you Sir! I just thought I remembered seeing somewhere that the upper control arm was different on the 2014 and wanted to make sure that I didn't order too wide of a tire
I think it was the lower that was changed but I may be wrong. I would also check out the 285x60x20 Duratrac (33.5x12) and the 285x65x20 BFG KO2 (34.5x11.5) these are not as wide and should give more clearance.
I can't decide if I want to go with a 33 or 34" tire. I love the look of the 34's that fill the fender wells a little more but figure I am going to lose more power and mpg. Trying to decide if it is worth it.
