OEM Part# for Sirius
Anybody know the OEM part# for a Sirius unit for my 2010 FX2 Screw? I have the button on the dash but not the actual Sirius unit. Any help would be appreciated
Sirrius
I found a Sirrius module and antennae at www.crutchfield.com for my 2010 F150. You will also need to get a cable that will plug into the Ford radio. I believe the price was around $70.00
Does it work with the Sirius button and display on the radio? Like it would from the factory?
I believe so.
Well, if the parts are the same, I have the OEM tuner out of my 2007 available.
I guess I'm gonna have to call the dealership to see if they can tell me. nablesbill I might be interested if the part#'s are the same
OEM part # for Sirius
Curiously I am having the same problem with a 2010 XLT. Depending on which dealer I talk to I am told that it can't be done, go buy a kit from Radio Shack, we might be able to rig something up for about $1000, and sure, we can get an installation for $475. Hopefully someone out there knows the answer?
I found this... Has anybody used this yet? I dunno if I wanna be the guinea pig that buys it first.
http://www.tss-radio.com/isimple-for...us-p-6952.html |
Call Crutchfield and tell them what your trying to do. The kit requires two pieces that I have listed below. I just ordered mine and should get them in the next few days. The local radio shops all told me there was no such kit. Crutchfield says this will work. The dealer wanted an additional $700 to provide the parts and do the installation.
541ISFD11 Peripheral Gateway for Satelli 2005- Up Ford/Lincoln/Mercury 169.99 607SCC1 SiriusConnect SC-C1 Universal Vehicle Tuner 49.99 |
Originally Posted by brannong
(Post 4228812)
Did the parts you ordered from Crutchfield work? If so any problems with installation?
I know it's a bit late, but for the 2010 the OEM gps/sat rad antenna part number is 10E893, and it's $75.08. There are a couple of associated cables to it as well 19A397A and 19A397B. I could not find a cost on those, and they may come with the antenna.
Those seem to be either wrong or partial part numbers. Where'd you get the info and pricing?
Hey Kirch. I found them on fordparts.com . Here is a link to the front page for the 2010 F-150. http://www.fordparts.com/Commerce/Ca...=Ford&mo=F-150 . Switch the 'search by' box in the lower left to 'part number' and use the 10E893 and it should pop up. I only found the cables in the associated diagram, never on a parts list. Hope this helps.
i did this, plugs right in. call sirius and your all done.
should work on any 04-08 |
