Can't view galleries
Why is it I can't view a anyone elses' galleries? When I follow the link, the upper right lists albums they've created, but there's no hyperlink available. Yes, I am logged in.
Here's my gallery |
The link that you've used to tie to your gallery is bad...
The correct link should be: https://www.f150online.com/galleries....cfm?gnum=3935 thorin's Gallery --Moved to Questions About the Site by RP RP :D |
It seems to be working correctly for me...
Is this the link that you claim isn't working correctly? https://www.f150online.com/galleries/index.cfm Anyone else having problems? RP :D |
I'm not talking about a bad link. I mean that when I click a hyperlink to another users gallery, all I see is the table with their truck and personal information. In the upper right it says they've got x number of galleries with y number of pictures and z number of views. How do I get to their pictures?
Here's an example gallery that I can't see the pictures on. Yeah, somehow I did screw up the link to my gallery. I'm still learnin'. Hopefully I did the following correctly. Thanks, Kurt Someone's gallery |
Hi Kurt,
That's not "Someone's Gallery"...that's My Gallery:D :thumbsup: . There's not a text hyperlink to the album pictures...you just need to click on the thumbnail picture above each gallery name. Did you try that? |
Originally posted by thorin ...Yeah, somehow I did screw up the link to my gallery. I'm still learnin'. Hopefully I did the following correctly. To view their galleries, all you have to do is click on the big picture with their gallery. IE: if they have a gallery named MODS!, click on the picture that is associated with MODS! and it'll bring up another window to view the pics. Is that the problem you're having? Still not sure I understand. RP :D |
NICE LOOKIN' TRUCK!!!:thumbsup:
I thought I liked the monotone better, but yours is SHARP!!! |
thorin,
Further consideration of your post makes me think that what you're seeing on your screen isn't what I see on mine when I view a gallery: https://www.f150online.com/galleries...5185-88707.jpg I know that that are some issues with certain web browsers. What operating system and web browser are you using? John |
JohnandDar:
I think you nailed it. This is what I see on My Windows XP system running IE6.0 with all the Windows Update components current. https://www.f150online.com/galleries...8716&anum=5753 Hopefully this shows my gallery with no visible picture links associated with the album in the upper right. How do I fix that. Rock Pick, I'm not one of those whiny babies that takes offense at every little thing. Much thicker skin than that. I appreciate your help. |
Well, it didn't show the image, but it does show a link to the correct image. How do you put actual pictures in the body of a message? I used "[IMG] link inserted here [IMG]".
Thorin, Went to your link, saw the same thing you did, lack of picture.
Went to your gallery page and I could see all the pictures in your album (7). BTW here's the one you wished to post, forgot the / before the img in the [img] https://www.f150online.com/galleries...5753-88716.jpg Try the simple thing, change browsers and see if that makes a difference. |
Originally posted by thorin Well, it didn't show the image, but it does show a link to the correct image. How do you put actual pictures in the body of a message? I used "[IMG] link inserted here [IMG]". That I can definately help you with. To get the image in the thread: Go to your gallery album and open the picture you want to insert in the thread. In the lower right corner, you'll see "Forum Codes". Click on that and a new window will open up with the image links for "Fullsize" and "Thumbnail". Copy which code you want and paste it into your message. Now, as far as your trouble viewing albums, I did a search and found a thread where another member had the same problem. Through trial and error, he found that he had ZoneAlarm installed in his computer and he had to disable "Banner/Skyscraper Ad Blocking" in order to view the album links. Might you have anything like that installed on your PC? Hopefully that will help, John |
JohnandDar:
That was exactly the problem!!! Thanks for the quick and easy fix. Thorin |
Originally posted by thorin JohnandDar: That was exactly the problem!!! Thanks for the quick and easy fix. Thorin |
| All times are GMT -4. The time now is 10:04 PM. |
