Incessant beeping under dash
Ok Ford gurus. When I start my truck, I get a loud beeping noise that beeps for about a minute. It’s not the dummy ding for keys or lights. It sounds like it’s coming from under the radio. I thought it was my alarm brain, but I unhooked it and still get the beeping. It cycles through about a minute of beeping every fifteen minutes or so. It’s driving me nuts |
Airbag auxiliary warning. The light in the cluster probably doesn't work .and. you have an airbag system fault.
Yup. Just started doing it when the airbag light burned out. Quick fix? |
Replace the airbag light, then fix the underlying fault.
I’ll get on the bulb this weekend. I’m guessing it has a broken clock spring since cc and the horn don’t work. P.O. installed an auxiliary horn |
