Labnerd |
01-05-2018 10:04 PM |
Assuming it is like my 91 302 and I'm sure it is, no, the balancer does not have to come off to change the water pump. FWIW, you should have a coolant by-pass hose that runs from the pump back to the intake manifold at the thermostat. Make sure to replace this little short hose. It can be a PIA to get the right one so make sure it fits before tearing it apart. For my 91, it is a pre bent formed hose meaning a piece of water heater hose won't work. If this hose breaks, you get to remove and reinstall the pump all over again.
