94 f150 4.9 fuel pump will not stop running
Turn the key fuel pump starts but will not stop. I have read the if the ecc timer was bad the injectors would not work dew to no ground but I can spray staring fluid in the intake and in will start and run on its on just really rough. My question is if the ecc timer is bad would the injectors work after its started with the starting fluid. It was my understanding that as long as the pump is on the injectors will not work
