F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Pre-1997 Models (https://www.f150online.com/forums/pre-1997-models-51/)
-   -   Engine bucks and jerks and won't accelerate (https://www.f150online.com/forums/pre-1997-models/513858-engine-bucks-jerks-wont-accelerate.html)
dieterschmied Apr 6, 2017 08:24 AM
I have a 1989 f150 6 cylinder with a standard transmission.
Upon acceleration the engine bucks and was doing better when I would either rev the engine and let the clutch engage slowly. I replaced the throttle position sensor and there was partial relief but now it went back to its old ways. And the engine sometimes will not even rev up starting from a light for a period (few seconds) and again I must rev it up a lot and then let the clutch engage which also results in burning the clutch.
For a while after replacing the TPS, it was better but it always bucked when it was cold and during acceleration but now it I give it full throttle it buck like a mechanical bull in a bar.
also, does this model have one of those fault or code reader? If there is, can you tell me which one I need to get?
Roadie Apr 6, 2017 10:39 AM
I don't know where you are located but around here, all the auto parts stores will check for codes free of charge.
glc Apr 6, 2017 12:40 PM
That's normally only OBD2, which didn't come till 1996. Here is how to retrieve codes from the old EEC system:
https://www.scribd.com/doc/34996350/...-and-Procedure
1995XLT Apr 6, 2017 10:06 PM
Check your fuel pressure - with a gauge,
