What is this part called?
Hi again,
1995 Ford F150, V8, 5.0 RWD What is this part called? Its behind the muffler pipe and in front of a square box (yah, what's that square box called too!). It seems to be leaking and I want to see if it is something I can fix myself with the correct gasket or bring it to someone. I was told to spray clean it first, then take another pic, so I can clearly see where the leak is coming from. If it is just a gasket thing, what do garages usually charge for that? Would I expect some other problems besides a leak in the gasket? https://i.imgur.com/oWqgFkY.jpg |
That would be the transmission pan(square box thing) it looks like the pan gasket may be leaking.it also appears that the rear main seal may be leaking as well
Originally Posted by fallguy666
(Post 5084995)
(Post 5084995)
Correct. Yes it is a fairly big job,
It looks like your oil drain plug is weeping a bit also, and while you are at it take a look at the valve cover gaskets. Your truck is pushing 20 years old, it's kinda normal with that many years. |
Originally Posted by jgger
(Post 5085048)
It looks like your oil drain plug is weeping a bit also, and while you are at it take a look at the valve cover gaskets. Your truck is pushing 20 years old, it's kinda normal with that many years. And if I change the oil twice a year or twice every 15 months, it should be fine right? |
Before you go throwing parts at fixing leaks you need to clean it all off and pinpoint exactly where the leaks are.
^^^Truth
(Post 5085105)
The rear main seal leaking is a very common Ford problem.
Believe it or not, sitting is usually the reason. The seal sits for too long and gets harder. So when you use it, it will start to leak to the point you can no longer ignore it. The transmission pan is most likely just loose. Might see if you can get at least a 1/4 turn on the bolts after making sure they are snug. To fix the rear main seal leak, you'd have to pull the transmission. The seal is only about $20, but the labor to replace it is $150 to $250 or higher. From your posts, I really suggest you get someone who can do the job and know what the parts are called.....lol! |
Originally Posted by dfwtxpatrick
(Post 5085228)
My 90 has been doing that for awhile, weeps just a little. But yea, usually from sitting. Mine's not used a whole lot.
I do not think that is a transmission fluid leak. More than likely just oil from the rear main seal and a lot of road grime and debris over the years.
Originally Posted by coobies5
(Post 5086083)
My 94 does have a small leak from the rear main, but I won't mess with it until after I move. Then I'll pull the motor & tranny to do complete seal replacements. The truck runs great, just gonna make sure it won't have problems in the future. |
