i need help this truck is pissing me off
i have a 96 f150 with the 5.8 and e4od trans and its 4x4 when in park it runs for a few mins then the idle dies down and then shuts off and when i put it in gear and go to take off it acts like it has no power but then when i have it moving it acts like it has a miss but it runs like a champ and does not die on me i have tryed so many things i have i have put new plugs new trans fliter went over all vac lines for leaks and the check light flashs tryed pulling codes and it will not give me any thing this is the first time i have had a truck that has beat me up like this and what does that light flashing mean because its fine onces its out of 1st gear please help i have a big mud bog coming up here so and i need it back up and runing right my truck she is my mud toy and i miss her runing right here is what happen i took the motor and trans out to change the cab out because it was shot put the new cab on the truck and put every thing back together and have been having issues with it and it ran great before i took it out and did not do any thing to the motor or trans why it was out so i do not know whats going on please any ideas would be help full
If your OBD2 scanner wont work the cig lighter fuse is probably blown you have to pull codes somehow to find a place to start troubleshooting otherwise its just going to be a crapshoot it would also be a lot easier to follow your post if you used some punctuation and broke it into sentences when was the last time you replaced the cap rotor and plug wires and fuel filter if the scanner is connecting and says there are no codes a flashing CEL means misfires
help
the lighter works and it has been awhile on the cap and rotor plug wires its been awhile and i have never change the fuel filter. i also found a bad plug today that was oil covered im taking that i have a bad valve seal or bad piston ring. i put a fuel cleaner and a oil add to it do day and it got better. it still is not right and as far as the light it will flash for a min then stops for a few mins then starts again is the a chance that it jumped timing a little to cause the miss fire
