sputter/misfire
I have a 91 F150 with a 5.0 EFI. I have sputter/misfire at crusing speed and, slightly at idle. It dosen't do it under load like when going up a hill. Here is what I HAVE replaced with NEW parts.
fuel pump front tank fuel pressure regulator ingnition module pick up coil distributor cap wires plugs "gapped .044" rotor button throttle position sensor idle air control sensor map sensor egr vacum soleniod air charge temp sensor temp sending unit vacum canister timing chain set o2 sensor Here is what I HAVEN'T replaced. egr valve "cleaned and works free like it should" egr posit sensor tad & tab soleniods I'm at my wits end on this I don't know what else to do. I have it timed at 10 deg BTDC. Could a partially clogged cat cause this? This is getting to be a pain in my . Thanks for all help in advance. __________________ If it won't come off get the blue wrench. 08 STX Scab 4X4 4.6L 3.55grs S&b cai, 2.5" exaust with 18" dynomax bullets, hypertech programmer, 2" leveling kit 91 reg cab 4x4 5.0 EFI .030 over 3.55grs nls 84 reg cab 4x4 351W .030 over 3.73grs ls |
did u notice if the distributer had play in it wile u were changing everything.
The distributor body is tight as far as internals go the shaft didn't have any backlash
Make sure the wires are run correctly and you are not getting crossfire. Best way to check is at night with no lights around.
could also be the pick up in the distributer
all new even seperated the 5&6 wires away from each other to prevent the notorious misfire that many people have told me about
what about the fuel filter and cleaning the injectors in chem dip and rebuldint them with new nossels filters and orings i had a shutter in acceleration and i rebuilt my injectors and it took care of the problem
rebuild kit has like $20 but make sure u get the one with the little filters to take the old filters out i believe i used a number 10 machineist screw and the chem sip u can get at any parts store i think i payed $20 for that also |
New filter haven't done any thing to the injectors sounds like a plan
Before you pull the injectors, you could try running a couple bottles of Techron through the gas. If it makes a difference, then you know it's the injectors.
that stuff never worked for me but its worth a shot especialy if u dont have to pull the plentem but if so it cheap and easy to do the longest part is waiting for them to be dun.
i took my injectors out at night and dissasembled them and dropped em in the chem dip then in the morning i came out blew them out with the air hose and rebuilt them and put them back in. make sure if u do it dontpinch or roll an o-ring or else ull have a leak |
I ran so much seafoam throught this thing it aint funny. I hate to pull the plenum especially after all the gaskets have been replaced. It dont sound like a hard job just hate doing that kind of work out in the driveway. Oh well if something goes wrong I have 2 other sets of injectors.
then clean n rebuild one of your set and swap them in. i do my stuff in my driveway/onecar garage i dont like taking my vehicals to someone else to fix.
also i know alot of people woulnt like this but i dont depressurized my fuel rail i drape a towle over them and use the pressure in the lines to help get them out but if u do dont forget the towle orelse gas will be everyware
Originally Posted by FoMoCo Power
(Post 4674441)
