F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Pre-1997 Models (https://www.f150online.com/forums/pre-1997-models-51/)
-   -   Fuel problem, I'm stumped (https://www.f150online.com/forums/pre-1997-models/456185-fuel-problem-im-stumped.html)
Atipsword Sep 2, 2011 02:50 PM
I have a 93 f150 with a 5.8, e4od, short box, 1 rear tank. When the problem started the truck would run crappy sometimes. I haven't driven the truck much in the last few years but when I did the problem seemed to slowly get worse. It is very hard to start and when it does start, pressing the accelerator stalls the engine. The cel test gave me a 126 and a 128 which are MAP codes, however the map tested out just fine with a vacuum pump and multimeter(on hz of course). I dropped the tank removed the fuel pump, cleaned it and it does pump. I don't have a pressure gauge however to see how much it is actually pumping or to check at the rail. I also replaced the fuel filter, cap, roter, plugs, and wires. I have ran lucas cleaner through the fuel system as well. I really cant afford to buy a new fuel pump if it "might" be the problem so any ideas would be appreciated.
glc Sep 2, 2011 02:54 PM
Go to Autozone and get a pressure gauge - they have them in the "loan a tool" kit.
Atipsword Sep 2, 2011 03:06 PM
Also I forgot to mention I replaced the pressure regulator as well. I don't have an Autozone near me and the local parts stores don't rent one.
bigboy5011 Sep 2, 2011 06:33 PM
have you checked the injectors?
You might want to run seafoam instead of lucus.
Lucus is more of a lubricator, seafoam cleans gunk out.
I do it every 3000 miles on my trucks and cars and keeps them clean, well as clean as they can be.
Atipsword Sep 2, 2011 07:45 PM
I have not checked the injectors, is there any way to get at the pass side without taking off the plenum?
losthillbilly73 Sep 3, 2011 09:42 AM
cant get to the bolts that hold the fuel rail but the plentums arnt had to take off just make sure u get a new gasket they are only a few dollars n cheap insurance
Steve83 Sep 3, 2011 02:53 PM
Originally Posted by Atipsword (Post 4670842)
...which are MAP codes...
No, they're diagnostic codes which mention the MAF. Codes aren't for parts - they're for systems. What's the WHOLE definition of each code? If one of them is "MAF open circuit/short circuit", then it's no surprise that your MAF tests fine but the codes appear.
I don't have a pressure gauge... I really cant afford to buy a new fuel pump...
Then buy a fuel pressure gauge. ;)
https://www.supermotors.net/getfile/...ssuregauge.jpg
