Low Pressure port?
Your right subford, it's clicking on and off and it's getting annoying.
I knew it! Hey thanks for that diagram! My only problem is, on the instructions it says to attach the cannister nozzle to the low pressure port, and I followed the lines and sure enough, the "low pressure port" fitting is much too small for the cannister nozzle. I hate it when things like this happen. Anyone have any ideas?
You have a R12 Low Pressure Port and it sounds like you have some other special fitting on your cannister nozzle. You need to install an adapter fitting from R-12 to your artic freeze fitting what ever that may be.
I know Freeze 12 has special fittings and I would guess artic freeze does too.
on
The "high pressure port" has a little sticker next to it that says R134a. Are there two types of freon?
on
"Freon" is a trademark name owned by DuPont & used for R-12 & R-22. The DuPont name for R-134a is "Suva". There are MANY other types of refrigerant; some legal & some illegal, as that 1st TSB describes. AFAIK, the only refrigerant currently legal in all 50 states for mobile A/C systems is R-134a.
