Won't start
Hello all, newbie here with a problem. My '94 F150 302 auto won't start. Turns over fine, got good spark. I put in a new front gas tank and new fuel filter on the frame rail. Both tanks have gas in them and both fuel pumps run when you turn the key just never fires. The only thing I notice is that there seems to be no pressure in the fuel rail when you depress the schrader valve. What provides the pressure? It is just from the fuel pump in the tank? Thanks for any help.
Originally Posted by Cruizin
(Post 3666230)
(Post 3666230)
Does the fuel pumps run all the time the key is on with the engine not running? |
Won't start
Originally Posted by subford
(Post 3666927)
The fuel pumps in the tanks.
YES Does the fuel pumps run all the time the key is on with the engine not running? |
You may not be pushing the inter pin in the valve on the fuel rail (manifold) down far enough.
You should put a fuel pressure gauge on the fuel manifold and ground pin #6 of the self-test connector and turn on the key. The gauge should read about 42 PSI and the pumps will be running with pin #6 grounded. |
Won't start
I will have to go buy a fuel pressure guage and check it. Does the fact that the pump shuts off mean that it is coming up to pressure? I did reuse the old pump and sending unit when the tank was replaced. It did run for a while after the tank was swapped but always started hard. Seemed to get a little better after changing the filter.
(Post 3667034)
(Post 3667034)
Won't start
If I swap to the rear tank shouldn't it start and run from that tank?
(Post 3667081)
If the rear pump is free pumping into the front tank with no head pressure then there may not be enough pressure to start and run the engine. That is where the fuel pressure gauge comes in, you have to know what you have so you know how to go at the problem. There is an outside chance if you do not use the rear pump the rear FDM may be bad also or it may be why the front is not pumping the pressure up. |
Your Fuel System:
http://i54.photobucket.com/albums/g9...FuelSystem.jpg The FDM: http://i54.photobucket.com/albums/g9...yAssembly2.gif The FPR: http://i54.photobucket.com/albums/g9...eRegulator.jpg Fuel Pressure Gauge: http://i54.photobucket.com/albums/g9...P0L_SS500_.jpg http://i54.photobucket.com/albums/g9...ssureGauge.jpg / |
Won't start
(Post 3666959)
Do you have spark when it does not start?
Does the fuel pump run all the time with the key on when it does not start? Also find out if you have fuel pressure when it does not start. Let us know what you find out. Here is a diagram of the self-test connector and with pin 6 labeled. http://i54.photobucket.com/albums/g9...PConnector.gif |
Labeled Diagnostic Self Test Plugs in the diagram below.
The location of the self-test plug: http://i54.photobucket.com/albums/g9...M/TFISPOUT.jpg |
Won't start
Is the self test connector located under the hood? Is it labeled EEC Test?
Yes I have spark when it won't start and no the fuel pump does not run longer than a second or 2. Once I locate the self-test connector I will measure the pressure and post the results. Without grounding pin 6 it reads zero pressure. |
(Post 3667836)
(Post 3667836)
Won't start
(Post 3667875)
Yes see above diagram.
YES |
| All times are GMT -4. The time now is 05:39 AM. |
