Broken Frame
It's been a while since I've posted on here, mainly because my F150's frame rusted through quite some time ago. Anyways.. I have a perfect running truck sitting in my front lawn, with piece of the frame basically missing on the drivers side, right where the bed and cab connect just about. After this winter I'd really like to get this thing fixed, even if its just to use it as a beater truck for a while.... Can I have someone weld it, or is there any other ways, or what are my other options?? Thanks in advance for any help..
-Dave |
It kinda depends on how bad the frame actually is, where the break is and also finding a shop that will work on frames. Some will, some won't. We have had frames on class 8 dump trucks both lengthened and shortened by 2 different welding shops. Both of them made what I would call a Z cut in the frame and them pulled them apart, made the same cut either on another piece to go into the frame or on the section to be removed. Then push the rear part of the frame back in line with the front section and weld it back together. Now this is the not important part, they put a face plate and a backer plate on the cut section(s) that went 2-3 feet past the welds in both directions. One shop bolted the backer and face plate on, the other welded them on. Both trucks are still on the road with no problems from the frame alterations.
Long story, short, yes it can probably be fixed. But is it really worth it? What ever you do MAKE SURE THAT YOU HAVE A CERTIFITED WELDER/SHOP DO THE WORK!!!! DO NOT DO THE JOB YOURSELF!!!! |
Thanks for the reply PHS79. I guess when i really think about it, its not worth it to get it back on the road, as much as I love the truck. I suppose parting with it is probably the best idea. It's just a shame that the frame, of all things, is what's broken.. just about anything else I'd be able to fix myself. Thats just part of living way up here in the snow, all that salt they use on the roads takes its toll after a while.. Okay, thats enough of my pointless rant, I'm just a little depressed thats all..:( .. me and this truck have had some memorieshttps://www.f150online.com/galleries...904-168250.jpg
-Dave |
:( My condolences on your loss brother. These trucks have a way of attaching themselves to us. Mine has developed a malignant melonoma just behind the driver's door, which gets me all choked up just thinking about it, especially since it survived a double frame repair just a couple of years ago. I think my next one will be a Bronco from Arizona.
With the prices of these trucks now, find another with a solid frame, strip your's down, and make a better truck from the pieces.
Adrianspeeder |
Adrianspeeder -Dave |
