Surge??????
I would check the Throttle Position Sensor (TPS). I have seen a ton of these go bad with the same symptoms you just described. The TPS is a potentiameter and they develop bad spots in them. So the resistance will either fall or rise greatly in certain spots instead of gradually. Usually, just off idle. This creates the surge you are feeling. If you accelerate harder, it won't do it because you push past the bad spot in the sensor with the throttle pedal. Hope this helps.
Originally Posted by PKRWUD
IMO, Seafoam is the best thing since sliced bread. If you want your truck running it's best, put a half can in each tank, and add another can through the intake.
Originally Posted by brino
How do you add it through the intake?
There are instructions on the can, but they say to let it soak for 5 minutes, which really isn't long enough. 30 minutes works much better.
