welding on truck
What he said, i've welded on trucks with the battery connected with all kinds of welders without any problems, but i only do that in emergencies, i always unhook the battery if possible. It takes 5 minutes to hook the negative battery cable back up and reset your radio and clock, thats a lot easier than buying a $500 computer.
Grind all the rust or paint off the frame close to where you will be working and hook the ground cable there.
-Jon
-Jon
I've welded the exhaust on mine and didn't bother with battery cables or anything, just had the ground somewhat near where i was welding. But with the bumper, if in the front, would be a definate disconnect at the battery for me, too close to the engine. I'm also working with older trucks though....
