limited slip or non...
Jack both tires off the ground, block both front tires to prevent rolling. Place trans in neutral, turn one, note the direction the other wheel is turning. If they are rotating in OPOSITE directions, you have an OPEN differential. If they turn in the same direction, you have a limited slip.
