1987 Ford F-150 Manual Trans Question
I have a 87 F-150 with a manual 4 speed with the granny gear. Yesterday all was fine with the shifting. Today, for no explained reason, I can not get it into 4th gear. 3rd gear will grind a bit to. This started all of a sudden with no prior incidents.
What should I check for first. Second if it might be the trans, what type of 4 speed is it, and what truck years will work. Thanks |
If it is a granny gear, it is most likely a NP435. New Process trans. Almost any trans that will bolt up will work, if you don't want the granny.
Robbie |
Robbie |
The bell housing will vary depending on what engine it's bolted to. Since you have the granny gear I assume you have the 4.9 six cylinder?
Robbie |
Originally Posted by Tuna
87 will not have an NP435 it should have a T18 or T19.
