Pinion shaft not going back in!
Old 04-21-2018, 05:46 PM
mrmike61's Avatar
Pinion shaft. Started on replacing the rear axle seal on 01 f150. Needed to turn axle to get to the C clips. must have already moved something because when I tried to replace pinion shaft it would not go in. How do you get it lined back up?
Thanks for any help, Mike.
Old 04-21-2018, 07:41 PM
Roadie's Avatar
Can you push in a screwdriver and move it around to align everything?
Quick Reply: Pinion shaft not going back in!
