11998 expidition abs false activation, no codes
Old 01-23-2014, 12:57 PM
JGAutoVP's Avatar
Hello, i am currently working on a 98 expidition, and i am having an issue with the abs system. no light, no codes. when your coming to a stop the abs will activate from 5-3 mph. using my snap-on verus, the wheel speed sensors read 3 mph at a dead stop, and will not return to zero, even reads 3 mph with the front sensors unplugged. they read close to accurate over 10 mph. Anyone had this issue?
Old 01-23-2014, 01:37 PM
1997 lariat 4.6's Avatar
clean your sensors.
Old 01-23-2014, 02:05 PM
JGAutoVP's Avatar
the abs module is reading 3 mph with the sensors UNPLUGGED and all sensors are brand new
Old 01-23-2014, 02:26 PM
hmm. In that case you sensor could be junk.
Old 01-23-2014, 04:27 PM
glc is offline
Highly doubt it if it's reading 3 mph with the sensors UNPLUGGED............
More likely a faulty module.
Old 01-24-2014, 11:13 AM
i ment module. My head was in the clouds yesterday...
Old 01-24-2014, 12:18 PM
JGAutoVP's Avatar
turns out the module doesnt read lower than 3 mph, i looked at two other trucks that are at my shop with no abs issues, and they both read 3mph at 0/unplugged. what i did find was that the tone ring was not centered on the bearing causing the false activation. it wasnt broken, but it had moved. i replaced the bearing assembly and all issues dissolved. hopefully this can be some help to others down the road. thanks for all input...
Old 01-24-2014, 01:15 PM
glc is offline
Interesting! Thanks for the feedback.
Quick Reply: 11998 expidition abs false activation, no codes
