rear axle seal replacement
when replacing the rear axle seal, does the new seal have to be packed with grease before reinstalling, Help!!
Originally Posted by golfdude57
(Post 4402479)
If you're talking about the cavity inside the seal you don't have to, but packing it with grease can help to keep the spring from getting knocked loose when you drive the seal in.
Seems to me it depends on the bearing, right? - Some you pack, others are sealed.
thanks for the help, installed the rear seal over the weekend, installed axle. all is working fine.
