Does anybody have a 99 4x2 with 3.73 gears (stock)
In a recent comparision done by a magazine they compared full size trucks.
(There is more about this in computer chips section)
They showed a Ford 4x2 with 3.73 gears as one of the competitors according to what I remember 3.73 wasn't offered on 4x2 in '99.
If anyone knows otherwise please post.
99 XLT 5.4L reg cab
4x2 120" Wheelbase
4 wheel disc brakes/ABS
5 star larait style wheels
Toreador Red/Silver
3.55 gears 255/70/16 OWL
Delta toolbox
Eclipse 5340 cd player
Memphis ARCS50 component speakers w/tweeters mounted flush in the door panels (excellent sound)
Sherwood 35x2 RMS amp for components.
Jensen 50x2 RMS for subs.
2 6.5" Bazooka tubes
Lowering shackles?
Columbia SC
99 XLT 5.4L reg cab
4x2 120" Wheelbase
Toreador Red/Silver
Delta toolbox
Lowering shackles?
Columbia SC
54regcab, you're right. The 3.73 is only available on 4x4 models.
1999 Lariat SuperCab Flareside, Amazon Green with Silver trim, 5.4L, 4x2, 4 wheel disc/ABS, 3.55 limited slip, towing package, fog lamps, sliding rear window, captains chairs, keyless entry with alarm, spray-on bed liner, bug guard, and K&N. http://www.csc.calpoly.edu/~bfriesen/truck.html
I have a '99 with 3.73 LS, but it's a 250 LD.
'99 F-250 LD 5.4L SC XLT 2WD 3.73LS in White/Silver (w/ EVERYTHING 'cept leather and engine block heater) -- added: SnugTop Hi-Liner & carpet kit, Donnelly electrochromatic/compass mirror, K&N filter, SuperWhite 9007 bulbs, IAS shocks, 3" Induction Airbox Mod, more to come... (Westin side bars, cat-back exhaust, electric fan, and Superchip are next)
Can't say about 2000s, but nowhere in the 99 owners manual is 3.73 listed for F150 except 4x4 supercab 5.4L auto.
If anybody has a F150 4x2 3.73 stock gears please post here.
Ture on page 35 of "the book" it does list 3.73 as option on XLT and Larait.
You will also notice on page 36 of "the book" 3rd column about 1/2 way down when you look up 4x2 towing capacity with 5.4L 3.73 gear there is just a dash there no #'s.
[This message has been edited by 54regcab (edited 09-26-1999).]
The only requirement for the 3.73 axle..that I see in the 99 booklet..is that you had to have the 5.4L V8. It says nothing about having 4x2 or 4x4..it does say it is only an option for XLT and Lariat...not offered at all for the other trim levels.
The 3.73 rear axle for 2000 is only offered with the 5.4L V8 in the 7700 payload group. 4x2 or 4x4 allowed.
[This message has been edited by Dustoff (edited 09-28-1999).]
Correct 54regcab..
I see it on pg 36..a dash under the 4x2 F-150 column..
Now look down at the F250 stats..the 4x2 5.4L V8 DOES have ##'s Notice that the 4.6L V8, F250 with the 3.73 rear also has ##'s? Weird!
Maybe the ##'s for the F-150 were not available for printing???
You win...I'll give you this one until a 4x2 F-150 owner comes forward...
hahahahhaha!!
hahahahhaha!!
When i purchased my truck about 3 months ago, i ask the dealer if i could get a 3.73 gear in it.They told me that it was'nt an option in 4x2s what ever the engine size.
1999 F-150 reg.cab short bed,NASCAR truck,black/ 5.4 /3.55/class III towing package/in dash cd player and 6 disk cd changer/17 inch wheels/airaid induction/flowmaster 40 series cat back/classic hood scoop
Hi 54regcab,
What does it actually mean:limited slip 3.55
or 3.73
I see so many questions about this number.
Is it that important?
How can I find out what I have?
1999 F150 XLT V8 5.4 L Automatic
Regular Cab,Styleside,ShortBed
Bright Red,5 spoke Lariat Rims
Single CD-player,Class 3 Hitch
Pace Edwards Roll Top Cover
Dual exhaust at the back
The Bright Red One
anadjako@wxs.nl
or 3.73
The Bright Red One
anadjako@wxs.nl
3:55 means it takes the driveshaft 3.55 times to turn the wheels one whole time. 3;73 means to turn the driveshaft 3.73 times to get one tire rotation. The lower the gears, like 4:10, 4:30, are quick off the line, but get bad gas mileage and low top end. High gears, 2:83, 3:08 get good mileage but are dogs off the line, but good top end.
Thanks 54regcab and fast46triton.
I knew it had something to do with gearing but didn't know about the driveshaft.
How many turns it had to make,I mean.
But how can you tell which gearing you have?
3.08 or 3.55
My truck came with hitch installed.
But don't know if it was factory installed or installed by the dealer who shipped the truck to Europe.
For towing it is better to have the 3.55 axle.(3.73 even better)I quess.
If the hitch was factory installed would they have changed the gearing then,knowing the truck is going to be used for towing.
The Bright Red One
anadjako@wxs.nl
3.08 or 3.55
The Bright Red One
anadjako@wxs.nl
